Nueva Benelli 2ue 756
Mar Ene 17, 2017 8:28 pm
2ue756
Model introduction
2ue belongs to Benelli (Benelli) street car series, Benelli is absolutely exceptional. 2ue756 Benelli is the latest entry car, equipped with Benelli is no longer the most powerful 1130 straight three engines, but water-cooled straight two engines, compact, lightweight, relatively inexpensive. The Motorcycle Design Association (referred to as MDA, its members are engaged in motorcycle design, development and production of people) more than 130 motorcycle designers as 2006 Open Category design champion prize.
Model parameters
The main parameters
engine: Water-cooled, DOHC 4-valve, in-line twin-cylinder engine
Bore X stroke: 88 mm × 62 mm
Displacement 756mL
Compression ratio 12.5: 1
Maximum horsepower 72.3 kW (10000 r / min)
Maximum torque 63.7 N · m (8000 r / min)
Transmission system 6 speed
Oil supply Electronic fuel injection
Braking System (Front) 2 × 320mm brake disc, radial 4-piston calipers (rear) 240mm single disc, 2 piston calipers
Length X width X height
Wheelbase
Tires (Former) 80/70 17 (after) 180/55 17
Seat height 805 mm
Curb quality
Fuel tank capacity
Highest speed
Re: Nueva Benelli 2ue 756
Mar Ene 17, 2017 8:35 pm
No confundir con la nueva BJ750 GS.
Es otro modelo según parece en colaboración con MDA (motorcycle design association)
