Honda 650F ABS Banner11
>Honda 650F ABS Blog_r10"
Honda 650F ABS 21420255-5a7f-436b-b01e-71de42da401a
Honda 650F ABS Img_2024
[url=https://servimg.com/view/19665713/53]Honda 650F ABS …
Honda 650F ABS 20220910
[url=https://servimg.com/view/19665210/35]Honda 650F ABS …
Honda 650F ABS Img_2010
Honda 650F ABS Empty Honda 650F ABS
Miér Nov 02, 2016 10:39 pm
Que alguien les diga a Honda que dejen de sacar estas preciosidades !!  Muy Feliz Preciosa !
2016 HONDA CB650F ABS specification sheet
Engine: RC83E DOHC inline four-cylinder water-cooled four-stroke
Bore x Stroke: 67.0mm x 46.0mm
Displacement: 648 cc
Maximum horsepower: 82hp @ 11000rpm
Maximum torque: 63Nm / 6.4kgf-m @ 8000rpm
compression ratio : 11.4: 1
oil supply system: HONDA PGM-FI electronic injection system-wide
transmission system: wet multi-plate reciprocating six-speed transmission system
transmission: chain drive
car Taiwan: Taiwan diamond car
front suspension: 41mm positive vertical periscope hydraulic fork
rear suspension: single shock gun in the home, seven preload adjustable
suspension travel: front 109mm (4.3 Inch), after 127mm (5.0 Inch)
rim: aluminum alloy rim
front wheel brake: double NISSIN way dual-piston floating caliper, 320mm diameter disc
rear brakes: single NISSIN unidirectional single-piston floating calipers, disc diameter 240mm
front tire size: 120 / 70ZR17 M / C 58W
rear tire size: 180 / 55ZR17 M / C 73W
antilock brakes: HONDA ABS anti-lock braking system equipped with
length x width x height: 2110mm x 775mm x 1120mm
wheelbase: 1450mm
seat height: 810mm
Gross weight: 208kg
fuel tank total capacity: 17L
Honda 650F ABS Empty Re: Honda 650F ABS
Jue Nov 03, 2016 12:05 am
Oh la la laaaaaaaaaaá!
Jue Nov 03, 2016 9:06 am
Wapísima, parece más la sucesora de la cbf600 que de la cb600f hornet, con 84cv.
Sea como sea, preciosa.
