Yamaha MT03 Banner11
>Yamaha MT03 Blog_r10"
Yamaha MT03 21420255-5a7f-436b-b01e-71de42da401a
Yamaha MT03 Img_2024
[url=https://servimg.com/view/19665713/53]Yamaha MT03 …
Yamaha MT03 20220910
[url=https://servimg.com/view/19665210/35]Yamaha MT03 …
Yamaha MT03 Img_2010
Yamaha MT03 Empty Yamaha MT03
Vie Oct 23, 2015 7:41 pm
Bonita no .... LO SIGUIENTE !  Sonrisa Cara también  Muy Feliz
2016 Yamaha MT-03 / FZ-03 Specifications:
Engine Type: 4 stroke water-cooled DOHC parallel twin
Displacement: 321cc
Bore * Stroke: 68.0 x 44.1 mm
Compression ratio: 11.2: 1
maximum horsepower: 31 kW (41.6 hp) @ 10,750 rpm
Maximum torque: 30 Nm @ 9,000 rpm (22.1 lb-ft.)
Start: electric start
Engine Fuel tank capacity: 2.4L
Fuel system: Fuel injection
Clutch; wet multi-plate
Transmission: 6-speed
frame; diamond-shaped steel frame
damping front / rear: telescopic / Rocker
front tires: 110 / 70-17140 / 70-17, vacuum tire
front brake: dual piston calipers 298mm disc
rear brake: single piston 220mm disc
length and width * height: 2090 mm ​​/ 745 mm / 1,035 mm
Wheelbase: 1,380 mm
ground clearance: 160 mm
Seat height: 780 mm
Weight: 165 kg
Fuel tank capacity: 14 L (3.7 gallons)
Yamaha MT03 Empty Re: Yamaha MT03
Vie Oct 23, 2015 8:08 pm
Esta si es super bonita pero hay que pagar mucho para conseguirla y por su precio puedes tener una moto de mas cilindrada, aunque no sea yamaha.
Dom Dic 13, 2015 9:28 pm
Aquí más fotos de la MT03
