- neilparrasSoy nuev@ aquí
Fecha de inscripción : 11/04/2014
sonido normal del motor RKS
Mar Abr 22, 2014 4:59 am
good morning fellow rks users
i am neil from the philippines, i have rks 150 it is brand new and i am having a doubt with my engine sound
please check this youtube link: [Tienes que estar registrado y conectado para ver este vínculo]
do you think i have an engine problem?
thank you
___________________________________________________________________________________________
usuarios de buena mañana compañeros rks
soy neil de las Filipinas, tengo rks 150 es totalmente nuevo y estoy teniendo una duda con mi sonido del motor
por favor revise este enlace youtube: [Tienes que estar registrado y conectado para ver este vínculo]
cree usted que tengo un problema de motor?
¡gracias
thank you
¡gracias
Re: sonido normal del motor RKS
Mar Abr 22, 2014 4:16 pm
Hi Neil,
This forum is only in spanish language but many of its members can write English so do not worry, oh yes, for normatives, you must go to the "presentaciones" and introduce yourself.
Here the shortcut:
Well, let's see, ok, do not worry about the sound of your engine is completely normal, you might need a simple valve clearance adjustment, but hold on, not right now, let your bike ride at least until the first 1000 Kms. to do it, remember that you are in the break in period, for more info, please refer to your authorized dealer or consult the owner's manual in the maintenance seccion.
Here the shortcut:
Miér Abr 23, 2014 2:29 am
i actually hear the sound from the clutch area, so im kinda worried. I hard break in my RKS (not following the 40kph running in). Mechanics from the dealers are not that familiar on this bike since it was released just november last year here.
Miér Abr 23, 2014 9:50 am
in Spanish please, I see that also speak you, so the English is not necessary
Miér Abr 23, 2014 6:30 pm
neilparras escribió:i actually hear the sound from the clutch area, so im kinda worried. I hard break in my RKS (not following the 40kph running in). Mechanics from the dealers are not that familiar on this bike since it was released just november last year here.
Do you speak Spanish? because english is forbidden in this forum buddy.
Jue Abr 24, 2014 12:53 am
Lo siento por eso. Yo sólo uso el traductor de google en español.
Oigo el sonido anormal en la zona del embrague. estoy un poco preocupado porque me rompo duro en mis rks no seguir la carrera en especificado en el manual. cuando empiezo mis rks en la mañana, el motor funciona muy suave a diferencia de en el video. en este momento yo realmente quería revisar mi caja del embrague si es la causa, pero con seguridad voy a perder la garantía de mi moto.
Jue Abr 24, 2014 2:52 am
The sound that I heard in the video you have posted is the typical noise of the valve clearance that needs to be serviced, I do not think that you have a clutch problem, anyhow, if you have doubts about the noise, you must go and consult it with your mechanic.
El sonido que escuché en el vídeo que colocaste, es el típico ruido de las válvulas desajustadas que necesitan ser ajustadas, no creo que tengas un problema con el embrague, de todas maneras, si tienes dudas acerca del ruido, debes ir y consultarlo con tu mecánico.
