Kiden 150cc
Sáb Oct 29, 2016 10:53 am
Esta moto china de 150cc tiene un precio de unos 800 euros en China.
Kai Code KD-150F Technical parameters:
LWH (mm): 1979 × 766 × 1082
Wheelbase (mm): 1296
Minimum ground clearance (mm): 170
Seat height (mm): 795
Curb Weight (kg): 125
Engine type: single cylinder four-stroke air-cooled mid-camshaft
Starting method: Electric / kick start
Fuel supply method: Carburetor
Bore × Stroke (mm): 62 x 49.6
Displacement (ml): 150
Compression ratio: 9.8: 1
Transmission: chain drive
Clutch: wet multi-plate
Transmission: gear stepped transmission, 5-speed international
Fuel tank capacity (L): 19
Frame type: steel frame
Type front brakes: disc brakes
Rear Brake Type: Drum brake
Wheel Size: 80 / 90-17
Rear Size: 120 / 80-17
Market Price: 5999 yuan
Maximum power kw (r / min): 10.0 / 9000
Maximum Torque Nm (r / min): 11.5 / 7500
Video
Video
Re: Kiden 150cc
Sáb Oct 29, 2016 11:14 am
Tiene partes de RKV, de RKS... jaja y me recuerda a una Kawasaki, y más en ese color verde
